- May 6, 2014
- 190
XUV Tailgate Questions:
1) When you swing the tailgate open, there is a small gauge black coated wire on the hinge side of the tail gate that has been bent back and forth so many times that it fell apart. It looks like inside the black wire cover the wire inside was possibly red? Does anyone know what this wire connects to/controls?
2) My tailgate latches have ceased to function entirely and I have been wanting to swap my winter tires for summer ones now that the weather is getting decent. I removed the six torx screws that held the endgate /tailgate trim panel on and hoped I would be able to find the manual tailgate latch release switches? Are they White levers? It sounds like from the information on here and the o.s. that you need to take the trim panel and some inner reinforcement panel off before you can access the manual switches? The attached photo is of my tailgate after i removed the trim panel. Is the reinforcement panel the black panel in my photograph that is held on by six or so bolts? Do you have to disconnect the two connectors attached to whatever the box in the dead center of the tailgate is? Can maybe someone walk me through the remaining steps to manually open the tailgate? Maybe highlight the correct spots in my photograph? Once I do that can I latch it by moving those white levers in the opposite direction?
