I'm having issues with my driver's side mirror. It is loose enough that it rattles. It's noisy when you close the door, but the real problem is that it vibrates sometimes when it's windy or when you're on the highway. Only the driver's side does this.
I have a video of the movement in the mirror. But the strange part is that the passenger side mirror seems to have the same exact looseness by hand. Yet it doesn't vibrate when you close the door nor does it vibrate in the wind. The wind vibration is the real issue, as it makes it hard to see when you need to use the mirror.
I'm not sure which of the two movements is the one causing the problem, but any suggestions on tightening it up?
