Windshield washer
BaDAppLe
I have a 2006 TrailBlazer LT,and wonder if I should have a low washer fluid notification ? If so I'd guess I have a bad sensor? Any help would be greatly appreciated!
I don't believe they have that option... I know my 06 doesn't..
I think the initial 2002 models had it, along with under-hood and glovebox lamps. Alas, the bean-counters at GM made the engineers take them out (called "decontenting") because they knew nobody really was going to refuse to buy the truck without that feature, and they could save $0.50 in cost.
Thanks for the info. I was just wondering why mine did not work,but I guess if it's not there its a good reason.
From the owners manual:
However, the rear window washer will run out of fluid before the windshield washer. If you can wash your windshield but not your rear window, check the fluid level.
I guess that's all the low washer fluid notification they give us.
I generally follow the "pick some up while i am thinking about it" rule. Even if I think i have plenty left, chances are pretty good that I can still split a jug between the TB and the wifey's ride.
The washer tank is huge. I hadn't filled it in a while so I filled it and it took a full gallon. Looks like it still had room for more.
WTB927240
