Will 33's fit
It is easy to trim and I do not think that chart really helps as no one seems to run a body lift only. You should be close to fitting, but the width of your setup may cause rubbing. I had 2 inch body lift and 2.5 suspension with 9 inch wide wheels and 33x12.5ish tires and had to take 1.5 inches from fender but easy to do and not noticeable really. See my front fenders?
Cut is same as back then but now it is more lift and 35s.
Mynamesjeff
