Will 20x10 ss replicas fit on front?
Slolt
4
OK, So im new to the tb platform but Ive been around the block when it comes to wheel and tire fitment. I am wondering if anybody has put 20x10 ss replicas on the front of a stock non ss. I have a 2003 2wd tb lt and i am looking to do a set of the ss wheels. I already have a set of 275/45/20 tires, just need the wheels. Id like to know if anyone has tried to put or has put the 10" ss wheels all the way around a stock height 2wd.
Please help. And thanks in advance
10,687
:undecided: You might run into some rubbing issues at a full turn. I haven't seen anybody post that they've tried 10" wide rims up front.
BlazingTrails
19,409
I believe you will have to have at least 1" spacers. I have 22x9" with 265/40-22 tires. I only have 1/4" of clearance between the tire and upper ball joint. It's on the inside corner of the tire where the arm come up to the ball joint. I have no spacers.
jrSS
Yup you can run a 20×10 wheel up front with correct tires and wheels spacers.
Slolt
4
Do you know what offset your 22x9's are? The ss wheels are a +45
jimmyjam
why do you want 10" wheels to run 275s? you can run those on 8" wheels just fine
you can run 315/35 without spacers, if you go taller sidewall ie 295/45 you need 1/2" spacer to clear the balljoint.
Fishermandude
