Hi All,
A quick question for you all. I am trying to change the inner and outer tie rods on my 03 Trailblazer for the first time. However, I've run into an issue with the tie rod tool I purchased (Powerbuilt Truck/SUV Inner Tie Rod Kit #85), which does not fit over the ball joint on the inner tie rod, so I can not get a grip on the tie rod to remove it. I also went to a local Advance Auto to see if I could rent one from them, and their Universal Tie Rod tool also did not fit.
So my question is, is there a tie rod tool out there that will fit an 03 Trailblazer out of the box? I also noted in some of the posts from the former forum that someone mentioned having to modify a tool they got from Harbor Freight (#96558) to get it to work. Surely, there must be a tie rod tool out there that fits the inner tie rod of an 03 Trailblazer without modification?
Does anyone have a tie rod tool they use that they could post the manufacturer/model number ? I'm really looking for something that does not need to be modified and will work right out of the box.
Much appreciated.
crawfish
Much appreciated.
crawfish
