Where to find front axle disconnect outer housing?
keepontruckin
82
Hey everyone,
I need a front axle disconnect outer housing, my front bearing and grease seal seized and failed significantly, and there is a little wear on the bottom of the housing where the first bearing sits, not the grease seal just the bearing...i'm afraid if I just replace the bearing it will get torqued and get ripped apart like the old one, after spending a few hundred dollars replacing most of the internals of the disconnect and the CV shaft I don't want to ignore this potential problem...
has anyone had any luck finding an outer housing, or better yet, have an extra laying around?
thanks,
-Rob
I have an extra outer housing. I had to buy an entire disconnect when I busted my inner housing trying to get it off the truck (That wasn't any fun) so I had leftover parts. You can have this one for like $25 shipped.
Returned. I got it out of the box, started cleaning off the axle grease, and it is covered in stress cracks! No idea why, I guess it came off my truck that way and I just never noticed. So sorry :frown:
keepontruckin
82
Thanks anyway
- i know that all years are compatible, but just to be sure the disconnects are the same for all 4x4 Trailblazers and envoys, correct?
gmac310
keepontruckin said:
Thanks anyway
As long as it has selectable 4wd and not awd like a Buick or a Saab.
keepontruckin
82
Well at first what appeared to be a poorly molded case looks to be a severely stress cracked one...also you'll see that I drilled and pressed pins in the case where the original molded ones sheared off...Im not worried about the pins, but should i be worried about the stress cracking? also should i be worried about the wear on the housing were the first bearing sits?
what do you guys think? should i use this one for a couple weeks until i could find a new one?
thanks,
-Rob
Update: I just ordered the ATP aftermarket disconnect....sucks I already bought bearings and gears, if anyone needs parts for a disconnect PM me.
Hm, that's similar looking to the one I had (minus the broken pins). The used one I rebuilt to put on my truck didn't have those stress cracks. I wouldn't think there is that much stress on that housing to crack it :confused:
v7guy
Concerning the cracks... I've had two apart, they both looked like that. All the pictures of them I've seen over on offroadtb looked like that too. I wouldn't worry about it personally.
The wear at the bearing I would be concerned about.
keepontruckin
82
yea the stress cracks and the pins didn't really concern me, but the wear on the bearing housing was enough to make me order the aftermarket disconnect.
Crud. Maybe my old outer housing is OK then? It has no bearing housing wear.
Sigh.
bravad'oh
44
Any body looking for these parts should check wrecking yards IMO. There are lots of the older ones ending up there now. I wanted a disconnect and I also needed an intermediate shaft but the yards all wanted me to take the front diff as well. $160 for the whole thing and I have a spare diff! Hope I never have to use it. The Stealership wanted almost $400 just for the shaft.:hissyfit:
Tcwest38
