keepontruckin
- Joined
- Dec 5, 2011
- Posts
- 82
Hey everyone,
I need a front axle disconnect outer housing, my front bearing and grease seal seized and failed significantly, and there is a little wear on the bottom of the housing where the first bearing sits, not the grease seal just the bearing...i'm afraid if I just replace the bearing it will get torqued and get ripped apart like the old one, after spending a few hundred dollars replacing most of the internals of the disconnect and the CV shaft I don't want to ignore this potential problem...
has anyone had any luck finding an outer housing, or better yet, have an extra laying around?
thanks,
-Rob
thanks,
-Rob
