The Mysterious GM 4.2L "Lost Oil" Check List:
(1) Very High Mileage Motor...with Piston Slap?
YES
(2) Dirty Engine Oil found inside the Air Intake Resonator?
(3) Carbon-Gas Gum Trapped "Low Tension" Compression Rings
(If (2) is YES... then YES)
(4) Infrequent or High Mileage Oil Changes
(5) Oily, Dirty Throttle Body & Oil leaking out from the Intake Manifold Runners Flange?
(6) Treated with ACDelco TEC (Top Engine Cleaner) YET?
??? See Linked Threads for Procedures
All of these Symptoms lead to Engine Oil being Pushed by Blow-By Gasses escaping around the Piston Rings pressurizing the Crank Case and Upper Valve Cover Spaces. After the Oil is moved upwards, it gets vacuumed through the Rubber PCV Tube in the front of the upper Valve Cover and it collects down inside of the Air Intake Resonator.
Ultimately, the Old Motor Oil passes on through the Throttle Body via Natural Aspiration and it winds up flowing down inside the Intake Manifold Runners. If the Intake Manifold is LOOSE (meaning having Less than 89 Inch Pounds on ALL of the IM Fasteners) then the excess Engine Oil can Leak out around the lower areas of the Worn Out IM Rubber Grommet Style Gaskets
(Three Figure "8" Shaped Dual Intake Port Gaskets) and then it gravity flows on down beneath the IM Flange onto the Driver's Side of the Engine Block.
And finally ... Whatever Old Motor Oil manages to make it
THIS far gets ingested into the Six Intake Ports in the Aluminum Engine Head and then pulled on down inside of the Six Cylinders only to be Burned Up along with the regular Inhaled Air and the Injected Fuel.
The Catalytic Converter somehow manages to combust most of this Residual Crap... so there will rarely be any Tell-Tale Smoke indicating there is any kind of problem. The Extra Gas-Gum and Carbon Trapping of the Compression Rings is THE Primary Culprit and the Instigator of this problem!
Good Evening All, I've read about this procedure here on the forum. I'm wondering if it would be OK to do, regardless of if I have carbon build up or oil consumption. I have noticed a small amount of oil accumulated in the intake plenum. I do have a little piston "slap" that goes away upon...
gmtnation.com
Hi all. I've decided to do the top end soak with A.C. Delco product. They make it in an aerosol also. Any suggestions on which might be better? After doing some add'l research...It appears the aerosol is made to use while the engine is running by spraying it through the intake. It looks like...
gmtnation.com
I have recently performed carbon cleaning on the pistons and valves using a method recommended by @MRRSM and I figured to document the experience for those who would like to pursue this in the future. The method involves pouring AcDelco Top engine cleaner in the spark plug holes. This is NOT a...
gmtnation.com
AC Delco TEC is available on Amazon:
