- Apr 17, 2013
- 63
What years are interchangeable on the I6 4.2 engine? Was there a changeover sometime to variable valve timing? I have an 05 and may need a new engine.
It went to a 58x reluctor iirc but I thought that was 08. 06 was MAF and the 1st head/exhaust redesign. They separated the trans controller out of PCM too. Separate ECM/TCM after 06.Mooseman said:There was a change I believe on 05 or 06 where the crank sensor reluctor wheel changed with additional teeth. I think unless you swap all the electronics, it's not an easy task.
