(2006 Trailblazer LT 4.2L 4X4)
Backstory - Recently had a P0171 and P0306 and couldn't pass inspection. I changed the air filter, cleaned the Throttle Body (Carb Cleaner), the MAF and MAP (MAF Cleaner - 12hrs + dry time), changed the Intake manifold gaskets and cleaned out the manifold, injectors, and head side of the manifold (Carb Cleaner). I'm now getting a P0106 and a P0171. I'm getting a very rough idle with the engine just dying as well. I have also tried changing the MAP sensor and giving the battery more than an hour disconnected. I am wondering if I forgot to hook something up here. What is this nipple?
I am hearing a whistling/sucking noise from this nozzle as well as this little cut out in the throttle body to intake manifold connection
If I block them with my finger, there is significant suction against my finger and the MAP sensor reading goes from ~21 inHg down to ~16 inHg.
Did I forget to hook something up here. I can't find any hose that would connect to it and I don't remember disconnecting anything there.
For reference I have OBDLink MX with which I can read codes and PID values. I am definitely more of a shade tree mechanic though - I bought this reader to troubleshoot this problem and am coming up empty. Any ideas?
Thanks in advance all,
-Pete
-Pete
