What is the sweet spot RPM wise when towing?
c good
662
I'm seeing this engine likes to generate best torque around 3600 RPM. So I'm thinking that's what I'll be planning on when pulling some of the longer grades. My travel trailer is around 1900 lbs, with a max of 2800 to 3000 GVW. I have the 3.42 Differential. PCM of N.C. transmission cooler.
Any suggestions for a sweet spot without beating up my Envoy?
Definitely tow in third going uphill. You might be able to tow flatland in OD but if you notice it hunting between 3 and 4, then keep it in 3. All depends on weight and wind resistance. You'll be able to tell what RPM it likes but it does its max torque at 3600 RPM.
Reactions: c good and BrianF
BrianF
1,273
West central Sask.
^^^ Bingo!
I've towed a bit with my Trailblazer. Mostly two horse trailers. On the flats or downhill, overdrive can work but it's just easier to deal with and easier on the vehicle to keep it in third.
Reactions: c good and Mooseman
Chickenhawk
790
On steeper upgrades, don't be afraid to drop to 2nd if that is what it takes to keep the RPMs above 3000. The secret of towing is to keep the RPMs up and just live with the gas mileage you are getting. You can also find the sweet spot of RPMs by the position of the gas pedal; if you can't decide between two gears, note how far down your foot is to the floor and then shift gears up. If you need MORE gas than before, then go with the lower gear.
IH1026
