This will be long, so please bear with me.
I was doing some grocery shopping earlier tonight and decided to make one last stop. I jumped back in my car, started it up, and left the parking lot. I was cruising about 30 when first my ABS and Brake lights lit up. About a second later my DIC stated "Unknown Driver". Then all the lights started going crazy on my dash. I decided to pull over ASAP and shut if off thinking maybe it needs to restart or something. I started it back up but all the gauges were still messed up and lights were lit up. Here is a picture of what I saw:
Tachometer and speedometer were still working but none of the others were. I replaced all my stepper motors two years ago, so they should be good. I figured, hey, I'll disconnect the battery and let the computer do a reset. BAD FRIENDLY IDEA. I came back out a few minutes later and reconnected the battery. Now when I turn the key the dash lights up with "Unknown Driver", ABS/Brake/Airbag/Battery/SES are lit, but turning to the start position will not crank. The battery is good and I changed it a couple months ago when the other battery went dead and tested bad at Autozone. I pulled and reseated the starter relay to no avail.
I started looking around and found this thread: http://gmtnation.com/f23/wierd-electrical-issue-lots-stuff-stopped-working-today-3523/ which is pretty much spot on for my issues. However, I have taken off and cleaned almost every single ground I can find. I've cleaned up four or five under the hood, the interior master ground on the passenger side of the tranny hump, and the ground just behind the driver's side strut tower that I believe is the ABS ground. My car did almost exactly the same thing as the video posted by Spalding1028 in that thread except he could restart his and the lights would reset.
Ok, here are the gritty details:
I haven't had any problems recently and haven't touched anything electrical. I did notice one of my Moog sway bar end links I just put on a year ago was starting to clunk a couple days ago and I replaced my rear diff fluid last Saturday
Megafuse has continuity and I know not to use it as a jumping point
Headlights work, domelights work and come on after removing the key from the ignition or opening a rear door- not a front door, fan works, radio doesn't come on
Windows don't work from the driver's or passenger's front doors but the rear door windows do work when activated at the rear doors. In fact everything I tried on the drivers door seems dead (windows, heated seat, locks)
All functions on the driver's power seat work (up/down, forward/backward, lumbar, etc.)
I've tried unplugging and plugging back in all the electrical connectors I could find (in case it's a little corrosion)
Key FOB does not work- I must manually unlock and lock all doors. I'm just glad my liftgate was in the locked position when it decided to do this because I don't know how to lock it without the electronics.
I don't think it's the ignition switch as it did it while I was driving and I have never had an issue (~2 years of ownership) with being flaky, but the possibility is there
I have a multimeter and a decent set of tools. Right now I'm leaning toward the data splice packs and it being either the ABS or driver's door module. It also looks like chethro had similar issues with the lift gate module. I had to leave it in the grocery store parking lot and walk the 3 miles back home so I won't get to try anything new until the morning. Any other thoughts? Thanks
