Any users of Torque Pro noticing PIDs not working after the recent update to 1.10.120?
I am seeing PIDs not working and it looks to be a header issue. PIDs that used to work with an Auto header now require a relearn of sorts. I monitored the commands Torque is sending and where it used to try variations of the command to get a response it is no longer doing so. At least at first. If I edited the PID and changed the header from "Auto" to the 3 byte form of the J1850 header it then worked. Afterwards, if I change the header back to Auto it then works as it used to work.
I am of the opinion that if we give it the correct header to begin with it would reduce overhead by eliminating the trial and error portion that continues to clog the airwaves even after the correct variation is learned.
