I have a little over 120K on my 2004 Envoy. I recently replaced the oil and filter for the trans as well as the gear oil in both differentials and changed the transfer case oil. After all this
, I am now getting a whine for a few seconds on start up, while the truck is idling and still in park. It does go away. I checked the fluid level and everything is fine there. I used a filter / gasket set from AutoZone as well as Penzoil Dexron III as that was the only Dexron III I could find. So Part two to this, is if I have to drain again and check the filter, should I use GM filter / gasket and can I get away with using Dexron IV or better in this trans without any issues? Does Mobil 1 make a dexron IV or better fluid?
Thanks all!!!
, I am now getting a whine for a few seconds on start up, while the truck is idling and still in park. It does go away. I checked the fluid level and everything is fine there. I used a filter / gasket set from AutoZone as well as Penzoil Dexron III as that was the only Dexron III I could find. So Part two to this, is if I have to drain again and check the filter, should I use GM filter / gasket and can I get away with using Dexron IV or better in this trans without any issues? Does Mobil 1 make a dexron IV or better fluid? Thanks all!!!
Welcome
