- Dec 10, 2011
- 285
Last year I bought an e-fan from pcmofnc. Recently picked up a transmission cooler, and afterwards got a transmission gauge with a pod.
So after doing some research I decided to tackle this long project today.
I decided to install in order the:
tranny gauge
e-fan
tranny cooler
Today tackled the tranny gauge:
Here is a link for the gauge install:
http://www.glowshift.com/instructions/7-Color-Series/GS-712-Transmission-Temperature-Gauge.pdf
I decided to use the transmission test port.
Jack up vehicle from drivers side.
Slide under the truck and remove the crossmember. It is held on by 10 bolts. 5 on passenger side and 5 on drivers side.
Next step is to drop the front drive shaft if you have one. It is held on by (4) 11mm bolts. Can be rotated by hand for easier access to the bolts.
Position it out of the way. No need to remove it from vehicle.
Next step is to remove the 13mm bolt (circled in red) that hold the transmission shift linkage. Bend it back a bit. Don't go crazy. Slide a long flexible wrench in between the bracket (circled in green) to access the test port bolt I forgot the size. Test port bolt is circled in yellow. It will take a bit of wrenching as the throw is small. It will feel like nothing is happening but the bolt will come out eventually.
Get your transmission temperature sensor and thread it in. I used a extra long flexible wrench to tighten it up.
Now go inside your vehicle and remove the (4) 18mm bolt from your drivers seat. Tilt the seat backward so its standing on its rear.
Remove the sill and lift the carpet. There you will see a rubber grommet in the floor. This is where the transmission shift linkage cable passes through.
Have some (2) 18 gauge wires ready. Strip them on one side.
Go back under the truck and crimp them to the 2 wires on the sensor. Wrap in electrical tape.
Poke a small hole into the rubber grommet underneath the truck and fish the wires through into the driver side area.
Get some wire loom and place the two wires from the sensor into it. Measure and cut from the sensor to the rubber grommet. Right behind the grommet you will see a small stud. Zip tie the wire loom to it.
Put back the 13mm bolt from the shift linkage.
Assemble the driveshaft into place and reinstall. I just hand tightened the bolt. Don't go overboard
Reattach the crossmember.
At this point your are done from underneath the truck.
This is the hardest part of the installation and the biggest PITA. Just trying to remove the test port bolt will have you cursing. Very hard to access. Impossible with a ratchet and socket.
Inside the vehicle now.
Take the black wire, and strip the end. I grounded it to the bolt that holds the seat into place.
White wire, run it to outside of vehicle for now.
Put the seat back into place. Attached the 18mm bolts.
Attach the gauge wherever you want. Wire harness plugs into the rear of the gauge.
Attach the green wire to the white wire. Crimp with a butt connector and wrap in tape.
At this point it was 3pm and was quitting time for me.
More to come...
tranny gauge
e-fan
tranny cooler
More to come...
