I wired up a basic brake controller and I can confirm power to the controller, and output from the controller when the manual button is pressed and when the brake pedal is pressed, but the indicator light on the controller never comes on (should light green then attached to trailer and change to orange / red as braking power increases) and the brakes never engage on the trailer. How does the controller know when the trailer is connected is there a measurable voltage / resistance value I should be able to check coming from the trailer? Does the dark blue wire under the driver side go straight to the trailer connector for brakes or does it have a fuse or anything else inline before reaching the connector?
Thanks in advance for any assistance offered.
Jason
Jason
