Torque Convertor never fully locks.
Sqrly
277
Livingston CA
Using CarScanner I'm seeing 50rpm avg TCC slip when traveling 65 mph with the cruise control on and the vehicle fully warmed up.
I found this Trans mod post here and read through it. I watched the video and read the comments below it. Others say this mod cures the issue I am seeing. I also saw mention of PCM tuning to change the shift behavior.
Q1: I would assume the torque convertor is supposed to fully lock up at some point?
Q2: How long does it take to fully lock up? I only drove a few minutes @65 (with the cruise on).
Q3: Can this change can be done through programming? If yes how could I do that?
For the PWM on the torque converter, it lets it slip on engagement up till it eventually locks up the clutch so you don't feel it. When eliminating that PWM, either through a tune, shift kit or this mod, it will feel like a fifth gear engaging.
Note: I just recently did the trans flush and filter. I filled it with Valvoline Dex 6. I ended up using 4 gallons total.
Buying a new valve and modifying it then doing a swap wouldn't be too hard.
Q4: Why does Amazon say this ACDelco #24227792 does not fit my vehicle, but that this off brand replacement does?
Car Scanner LogFile.brc
TJBaker57
3,376
Colorado
Mine goes to full lockup. However mine has been rebuilt and I have no idea what exactly was done in the rebuild. Nothing special was requested for the rebuild.
Sqrly
277
Livingston CA
Sqrly
277
Livingston CA
TJBaker57
3,376
Colorado
Excellent link. My TCC is working exactly as intended.
I have long wondered if my TCC was altered in some way during the rebuild. Others here have said that theirs always has some slip where mine locks up solid.
My Yukon transmission was also rebuilt by the same shop and it also locks solid.
Sqrly
277
Livingston CA
Yours does not look correct to me. It's locking up (98%) in every gear just before shifting to the next. Shouldn't it only lockup in 4th?
I can't explain that rpm spike to 4500, did you lose traction? The math doesn't add up. A 3000 spike in RPM with only a 300 RPM slip.
TJBaker57
3,376
Colorado
Remember what I explained about how a Tech 2 displays the TCC duty cycle? The higher the percentage the more TCC apply pressure is released. So 98% is not lockup but full release.
And I think it can also lockup in manual 3rd.
There was a downshift there. From 4th with lockup down to 2nd with full TCC release.
Sqrly
277
Livingston CA
Yes, I remember. I was reffering to the five 0 rpm points in the TCC Slip RPM graph. The downshift explains a few but the first one appears to happen at 20 mph.
Reactions: TJBaker57
TJBaker57
3,376
Colorado
I am going to be revisiting the subject of TCC lockup and my perceptions of the reported values. Our friend @AmpOverload has contributed some findings that have me questioning my conclusions from back in June 2022 when I first experimented with this data point here in this post:
As for specifics in the screenshot I posted above I think what we are seeing is the result of a great deal of latency in my data stream. You see the screenshot displays just a few of the data points I was recording. There were about 70 data points active and requesting that many PIDs can lead to each PID only getting a response every 5 seconds or so.
cantaris
