Not exactly Tech2 related but this site will give you info on the latest calibration available for your various modules and PCM. Just punch in your VIN and check the particular module. For example, on my 02 TB, there were several updates for the PCM for idling issues, the fan, overheating and shifting.
<dead link> See later post.
This is for information only. Won't allow you to download or actually update anything but will tell you if there is an update available and if it addresses a particular issue instead of wasting time with TIS2000, which basically gives you the same info.
GM Vehicle Calibration Information
VIN: 1GNET16S526134103
Controller: PCM/VCM Powertrain/Vehicle Control Module
Calibration History for: Operating system
Part Number CVN Bulletin # Description
12587430 0000D75E - New calibration to improve idle stability
12579238 N/A - Operating system software replaces 12571911, 12213305 and 12575262
Calibration History for: Engine
12591954 0000FF37 - New calibration for diagnostic enhancements
12587441 00003A8F - New calibration to improve idle stability
12583556 000033BA - New calibration to correct cold idle fluctuation at altitude and/or warm hesitation on acceleration
12579249 0000AF11 - Calibration to correct cold start idle surge and hesitation
12576999 0000ABC0 - Engine calibration
Calibration History for: Transmission
12583717 0000F076 - New calibration to correct cold start/shift problems
12579259 00007A11 - New calibration to improve feel of 1-2 upshift
12573458 0000AE39 - Transmission calibration
Calibration History for: Speedometer
9351579 0000A898 - Speedometer calibration
Calibration History for: System
12596395 0000ED28 - New calibration to address customer complaint of overheat condition.
12587759 000030A6 - Enhanced Calibration for Cooling Fan Noise Reduction
12583726 00000E9A - New calibration for improved fan control
12577539 0000CB8A - System calibration
Calibration History for: Electronic Throttle Control
12571574 00003BC9 - Electronic throttle control calibration
