Shdwdrgn
- Joined
- Dec 4, 2011
- Posts
- 634
I've been working out a pattern to do my own steel bumper, and in the process I'm comparing different techniques for the construction. The bumper with have a 2" receiver and two tow rings, so it has to be strong enough for that. I will be building a custom center-guard (push-bar) that will bolt onto the front edge. If I have a support across the center of the guard, the area from this support and the top of the new bumper would be large enough to mount a winch, so it would be nice to have the bumper strong enough for this kind of stress, but I have no idea how to determine what kind of reinforcement would be needed.
So there are two schools of thought on the design... I could just go all-out and build the whole thing with 7ga (3/16") steel. Or I could try and lighten it up a bit and use 10ga steel (which is in-stock at my local welding shop) for the outer 'wings' of the bumper, and only use the 7ga for the center where it mounts to the truck frame. However after making rough calculations of the square inches of all needed pieces and figuring out how much they weighed at various gauges, I've come to the conclusion that in the end, the most I can save is about 20 pounds. Not counting the 2" receiver, the frame mounts, or the weld joints, I've come up with about 68 pounds of steel for the absolute lightest I could make the bumper... which means that building it completely from 7ga steel only puts it at 88 pounds.
Considering the effectiveness of a bumper in the case of a front impact (rocks or other vehicles), it really seems like that extra 20 pounds of steel would be greatly welcomed when I actually need it. However since I don't do any 'serious' off-roading, the only likely impact would be from a collision on the road. This then raises the question of how safe it would be to drop down to 8ga or 9ga steel for the entire project? And would any of these gauges be strong enough to hold a 6000 or 9000 pound winch mounted as mentioned above?
Of course the final solution will also be including a radiator skid, which will add a fair amount of weight itself, but in the end I want to find a solution that provides decent protection for my truck without destroying my gas mileage completely.
I definitely welcome any comments on the matter!
