I think I have TCC flutter. The symptoms seem to point that way (I thought it was engine issues at first).
2004 Envoy i6
No mods
Recently replaced:
Fuel pump
Fuel Filter
Variable timing cam/crank solenoid
Cam sensor
Plugs
Air filter
Cleaned throttle body
Thermostat
Temperature sensor
...all to try to resolve this problem. (I was convinced it was an engine issue)
The O2 sensors replaced 2 yrs ago
All fluid changes last summer (Transmission, Transfer case & diffs)
No codes using scan tool. (pending or otherwise)
Once the Envoy warms up (about 5 miles), holding a constant speed the engine varies by about 300 rpm giving a surging sensation. It's very rhythmic. From reading, searching and cross referencing I think it's the TCC flutter.
The more I read the more confused I get. I've read posts here, at the offroad site, and the "other" site.
I do some towing, very little offroad... mostly daily driver stuff.
I looked at the shift kit:
TransGo Engineering Solutions
Should I get the SK 4L60E or 4L60E-HD2? The writeup I read had the HD2 but got confused when I read other posts whether the HD2 is needed to fix the problem or they just wanted to further upgrade. Would it be worth it to get the HD2? Is this the kit to fix the problem?
Do I need to buy a big honk'in kit with corvette servos & stuff or will the kit from TransGo be all I need? I just want to fix the flutter but don't mind spending a bit more if it will help make the transmission more reliable/last longer. I really don't care about making the truck into a performance machine... just a reliable one.
I appreciate any advice any of you can give.
BTW, I'd prefer not taking the transmission out.
Thanks!
2004 Envoy i6
No mods
Recently replaced:
Fuel pump
Fuel Filter
Cam sensor
Plugs
Air filter
Thermostat
Temperature sensor
Thanks!
