TB quad brakes/dual turns on the cheap (halogen and LED verified)
MAY03LT
Delmarva
I got this crimper and....it crimps!!! Instead of buying the connector kits again I'm just going to get the pins, crimp/solder new leads, and reuse the connectors. Then undo the cut wire version and slap the harnesses back in. It will be cheaper and faster to do it this way.
Yacdogg
92
Hello, I might attempt this tomorrow, just quick question, sorry, noob to electrical mods. do I go from Red (at taillight) to Yellow (at trailer harness) on Left side (Driver Side ?), then Red (at taillight) to Dark Green (at trailer harness) on Right side (Passenger ?). also, when I splice wire at taillight harness, I would go from wire closest to harness that plugs into taillight board, correct ?
MAY03LT
Delmarva
Yes, red from each tail light wire will go to the second and forth pins as shown in post 36 picture 5.
And yes, left refers to drivers side and right is passenger.
Yes, you want your splices to go the tail light side of your cut, as shown in post 36 picture 6.
Coolness! I'll be on from time to time tomorrow so if you run into a jam feel free to post.:cool:
Short Bus
1,906
No, the red is the wire that he added. At the tail light harness you cut the 2 blue wires and use the power from the trailer harness to power your bulbs. Here's the wires you need (tape or cap off the unused side of these wires)
Here is his wire from the trailer harness to the 2 blue wires (I used these)
Yacdogg said:
to Yellow (at trailer harness) on Left side (Driver Side ?), then 2 blue wires (at taillight) to Dark Green (at trailer harness) on Right side (Passenger ?).
You are correct for the trailer harness, I used red scotch locks here (Like these)
Yacdogg said:
also, when I splice wire at taillight harness, I would go from wire from harness, not coming from front. correct ?
I think your saying the socket side of the wires you cut, if so yes.
Yacdogg
92
? ? ok, now im alittle confused... so I need to splice 2 blue wires in each (right and left taillight) then on Left attach to Yellow wire on trailer harness, then on Right attach to dark green on trailer harness. does each blue wire have to go to a seperate wire, or do I put them together to one wire, then that to the yellow (and dark green) ?
MAY03LT
Delmarva
I think you got it. On each side, wire them together at the tail light connector and run the single lead to the trailer connector.
Short Bus
1,906
:iagree: Both blue wires and your wire coming from the trailer harness can go in one crimp connector (make sure you tape it up) or solder and heat shrink them.
Yacdogg
92
Hello, got a problem. I hooked them up, the right side work right [video=youtube;NFHk5jcM2vI]http://www.youtube.com/watch?v=NFHk5jcM2vI&feature=youtu.be[/video] But the right side doesn't blink together [video=youtube;CyG-o-BeZfE]http://www.youtube.com/watch?v=CyG-o-BeZfE&feature=youtu.be[/video] and when I put on the brakes all four come on how they are suppose to View attachment 21319 PLEASSSSE HELP ! !
Short Bus
1,906
Check the brown wire, that should be the running lights. It could also be a burned out bulb, the bright and dim use different filaments. move the bulb and see if the problem follows the bulb. If it's the bulb you can just put it in the old turn spot. That socket doesn't use the dim filament
Yacdogg
92
what brown wire ? I just put new bulbs in all of rear lights. (sylvania silver stars)
Short Bus
1,906
The brown wire is on the far right on the plug in this pic
Yacdogg said:
would the brown wire make the turns not blink at the same time ? also, the left side is the one that doesn't flash together, but the right is the one that doesn't illuminate
The left side looks OK to me, the tail light is lit making it look a little different.
Yacdogg
92
but now they both flash differently (as left did, POSTED ABOVE) and not at the same time (as right did POSTED ABOVE) [video=youtube;kTAj336y1C0]http://www.youtube.com/watch?v=kTAj336y1C0&feature=youtu.be[/video]
Short Bus
1,906
Turn the headlight off and see what they do. I think it just looks that way because of the running lights. You could get a set of modded boards from May, or make your own (it's a PITA) to get quad tails
BTW what was the problem?
Yacdogg
92
I tried with running lights off, yep it just way it looked with them on, thanks for the help. also what do the modded boards do ? any pics someone could post ?
Short Bus
1,906
With the modded boards you get quad tails also. As a bonus you can also make the boards run standard led bulbs instead of the more expensive SRCK bulbs.
http://gmtnation.com/f33/modding-trailblazer-throttle-body-tail-light-boards-non-srck-leds-2046/
Here's your tails
Here's my truck with quad tails
I also have these LED's in the tails
[EBAY]320866380327[/EBAY]
and these for the license plate
[EBAY]150827419288[/EBAY]
BaDAppLe
51
I have the led spyder smoked tail lights , and was wondering if this would work for me? Do I need to just wire up as per the diagram? Thanks
Short Bus
1,906
I don't see why it wouldn't.
C-ya
1,098
MAY03LT said:
Well guys I have an update on the harnesses and it's not a good one. They've been in the TB for two weeks now.
Last night I noticed the park lights on the drivers side looked a little dimmer then the pass side. With a tap on the lens (that is the first step, right???) they went bright again.
I depinned and inspected all 16 crimps and these 2 had spread.
I know these things were LEGIT when I built the harnesses so I'm really thinking that the bass is the root cause. My system can move things in other vehicles and with these connectors a foot or so away from the port it is a strong possibility. But I can't rule out an assembly error.
It may be overkill, but that's why I solder all of my crimped pin connectors. I know you got a new crimp tool and fixed it, but I did it even when I had the top dollar crimp tools when I worked for a major appliance manufacturer in SW MI building custom harnesses in the electronic development lab.
Edit: Just saw Blckshdw said that back when the thread was current. Missed that part in the read.
4,047
MAY03LT said:
Do you just tape off the blue wires or do you join them together and tape them off?
Tape off individually. Don't join them together or you'll backfeed circuits and cause all sorts of whacky issues.
4,047
Thank you mate. I'm sure I saw a photo somewhere here but couldn't find it.
4,047
All done...but I have a question. With my lights on both my indicator lights on the dash are very dimly lit. They flash normally and are dark when the light are off but as I said, are dimly lit when the lights are on. Anyone else have this or know why?
10,791
:undecided: Sounds like your parking lights are backfeeding into your turn signals somewhere.
4,047
Don't know why. I followed the instructions implicitly. I wonder if may's board are doing it?
Short Bus
1,906
I don't have that problem :confused: Do you have 1 wire (per side) feeding both bulbs like this pic?
4,047
Sure do. I can live with it because they are very dim, but it's annoying all the same.
10,791
I guess if it got too annoying after a while, you could always introduce a diode inline with your turn signals to block the backfeeding.
4,047
Can you do a Ricky and splain? Please? Where on the line etc.
10,791
Anywhere on the brake/turn line coming from the trailer connector, before you split it heading into the tail light connector.
This way, when the brakes or turn signal come on, the signal travels through the line like it should. But when niether is on, AND your parking lights are on, whatever backfed signal that's currently getting through, will get blocked by the diode, and your indicators in the cluster should stay off like normal. Make sense?
4,047
Sure does...next question because I have NFI, what size diode would you recommend and would there be a polarity type issue where it has to go on a certain way?
10,791
Any diode rated for at least 12V should be fine I would think. Their polarity is what makes them work for this situation, they are usually marked by a stripe on the 'ground' side, which would face towards the tails.
A quick Ebay search turned up these (from US sellers)
[EBAY]180433429161[/EBAY] [EBAY]360465682639[/EBAY]
4,047
Thank you sir. :tiphat: Your blood's worth bottling!!
I see you have a 2002. I think GM kinda did some wiring goofs on the 2002 trucks here and there. My 2002's front signal sockets for example aren't wired right either. They work, but technically shouldn't be wired the way they are and it does cause minor backfeed into the parking light circuit that I can see make my rear running light dimly flash (yes it is the front socket causing this, because if I disconnect the front bulb I don't get the dim flash in the rear park/brake light).
10,791
You're welcome, and only if you're looking to market a mosquito attractant... :hopeless: :sadcry:
:rolleyes: I was gonna say Matt is just a trouble maker, but I guess that explanation works too... :raspberry:
4,047
Thanks...I think! :biggrin:
The back feeding didn't start until I did the mod. But, my front park/turn sockets are SRCK, not regular like the majority of 360's...work that one out!
SteelCityFan
63
I figured i would post in here instead of starting a whole new thread, but i was wondering something about doing this. I have LEDs in both turn and brake lights as well as switchbacks in the front. So this brings the total to 3 LED markers on one side if both LEDs in the rear are flashing. Would a 3 ohm resister that I have on there currently be enough? or could someone point me in a direction I might need to take like adding another resister or something. Thanks!
Short Bus
1,906
If it works now you're good to go.
4,047
:iagree: Your only choices are 3 or 6 ohm. 6ohm for either front OR rear LED's, 3ohm for front AND rear LED's.
SteelCityFan
63
Okay I did this last night and worked out great! Except for the fact that you can tell I have two different types of LEDs in the turn and brake, but that will all change when I get my modded boards from may and I put in all my new LEDs!
This is how I did it with the resistor, connected the one end into the ground coming in and crimped it with the signal coming in from the trailer harness. Then I just crimped the wires coming from the plug and it all works! And the perks of having a friend that works at an installation shop are getting weatherproof butt connectors for free!
eddiekeyton1985
