hello everyone.
My car has recently become longer time for the engine starter to rotate.
Last week, the rotation was about to stop, and then the engine started.
There is no problem with the battery.
I decided to consider replacing the engine starter.
Before the purchase, I plan to clean the two wiring that leads to the starter motor.
However, I think it will be necessary to replace it someday.
The 4.2 engine seems to be different from the other models for the 06-07 starter.
I found many available part numbers, but the typical ones are:
06-07
ACDELCO 3371118
ACDELCO 3362065A
GM GENUINE 3231639
GM GENUINE 89017846
Whichever I use, it seems to be suitable for 4.2 4WD in 2006.
However, these were different in Power Rating.
2.0kw
1.7kw
1.4kw
Which one should I use?
Is there any important problem with the difference in Power Rating?
There were sites that needed to choose whether it was 4WD or RWD.
For example, is Power Rating 1.4 originally for RWD?
Also,In addition to cleaning the cable that leads to the starter, is there anything to check?
I think the starter itself will be grounded, but are there any other relevant wiring that needs to be inspected?
thank you very much.
06-07
ACDELCO 3371118
ACDELCO 3362065A
GM GENUINE 3231639
GM GENUINE 89017846
2.0kw
1.7kw
1.4kw
