- Aug 25, 2012
- 955
Hello again everyone. I have an 2004 Envoy with 126k miles on it and since I bought it with 100k miles on it the rear end has had a bit of sag to it compared to the front. I haven't measured it yet but I would guess it is like a 1.5-2" drop in the rear. Even before I loaded down the back of my truck with my system it still was down a little. My question is what kind of springs are out there that are heavier duty than the OEM ones for the rear? I can tell my shocks in the rear have seen better days because it bounces quite a bit back there and I will be doing spring and shock replacement and from what I can see on here almost everyone recommends bilstein shocks for the rear. Where can I get better springs at? I was thinking that just doing the spring and shock replacement would help get the back end up higher without having to replace the stock bushings to give a lift. Also I have around 700 pounds of weight in the rear of my truck at all times from my system so keep that in mind. I also do not have the air suspension on mine, just the shock on the outside and the spring in the inside part of the axle.
Thanks in advance for your help guys!
