Ok ..... I know its not a GMT platform, but my Sunfire is part of the GM family
Please feel free to move if this doesn't belong in this section.
Anyway ... I need to check to see if the wiring to the washer pump on my '02 Sunfire is working or not. I am a newbie when it comes to using a multi-meter. My question basically is, how do I use the multi-meter to check for voltage on the power cable going to the pump. The cable going to it has 2 wires - 1 red I'm assuming is live and 1 black which I am assuming is ground.
Please don't shoot me for asking such a dumb question, but I'd really like to see if this part of the wiring is good. I will also check the fuse to see if it is blown.
Please feel free to move if this doesn't belong in this section.Anyway ... I need to check to see if the wiring to the washer pump on my '02 Sunfire is working or not. I am a newbie when it comes to using a multi-meter. My question basically is, how do I use the multi-meter to check for voltage on the power cable going to the pump. The cable going to it has 2 wires - 1 red I'm assuming is live and 1 black which I am assuming is ground.
Must have been leaking for a while and I didn't notice. I think the transmission is on its way out because of this (making some strange sounds).
. I can feel the large plug you mention. I even tried removing the drivers tire and trim in the wheel well to get a better look at the battery plate. During this process I found this ....
