STRUT PISTON NUT SIZE ?
KEEBZ489
250
Howard Beach NY
ive been looking for bilstein struts and i got them finally , along with moog springs and kyb mounts..... only thing is the nut for the strut shaft is missing from both. i wanted to put them together and just swap everything out. anyone know the nut size ? worst case would it be the same size as the stock? the struts came with the lower bolt and nut where it gets pinched in the knuckle only
also the struts are all chipped up , i personally dont care , but hope i didnt het someones returned crap
Sounds like you did. They should come with the nuts. Contact the seller.
atza
