Stopping Suddenly Got Harder. Possibly Master Cyclinder or Check Valve?
CaptainXL
So I replaced the Wagner Thermoquiet pads I put on my truck last November after hearing much hoopla about them. As it turns out they did not work well with my Envoy. They always exhibited a screetching sound like a city bus stopping. The pedal feel was not right either.
I switched to the Wearever Platinum ceramic pads from Advance Auto a few days ago. Immediately after changing to these pads I took the voy for a test drive and it was great. No noise and also the braking was excellent and it only took a little pressure on the brake pedal to come to a stop. Just like it should from the factory.
I then let the truck sit overnight...
I went to the store in the morning and the bad braking problem is back. What I am experiencing is weird. Yesterday I was able to stop the truck with little pressure but today it takes about double the foot pressure to come to a stop. The only immediate thing I can think of is that maybe the check valve is somehow screwy. When I take it off the booster I hear a swoosh sound so the booster is holding vacuum. What else to check?
I would put a vacuum gauge on it in a place I could see while driving.
CaptainXL
OK. Monitor engine vacuum before or after booster check valve?
CaptainXL
At the booster, since that's what affects pedal pressure.
Any particular reason to test the booster with the truck running? I have a vacuum pump and can test it that way. Does that sound satisfactory?
jlhorine
