I happen to connect up my torque android device today for a run to get my trailer.
Everything looked the same in terms of expected responses... LTF trim was basically "0" at idle and moved up a bit 2-3 ish during the drive. STF trim was "wagging" back and forth at idle and drive. Vacuum looked good, high at idle, lower at drive depending on throttling.
I was going down the highway and was ready to pull over for the exit, foot off the gas to coast in to the exit speed. I just happen to notice a "spike" in the STF trim up into the 20's. Thought this was rather strange as I thought with throttle closed, that perhaps fuel would trim lower a bit on both LTF and STF.... not that I have watched that much before. It just seems somewhat wrong to significant rich the mixture. I would expect more that the throttle motor would potentially open / crack a bit for air /fuel ratio "maintenance".
I was watching the same type of response later just going down a driveway at slow speed and taking off the gas, same spike in STF. I tried to duplicate the response a couple of times and couldn't so I can't say I know what conditions cause this but it is perplexing for me and was wondering if anyone has an understanding of what this is and if it is expected. I am almost thinking that there is a "mass air response" issue... where the system is thinking a large incoming of air showed up and thus the response is more fuel to maintain the ratio.
Anyways, comments and ideas to point me in a "don't worry" or "yes it is a problem and this is the area" direction. Thanks
