- Apr 30, 2013
- 199
I have several noises that I know shouldn't be (or probably shouldn't be) part of my truck.
1. When I go over a bump, a bump at a low speed, I hear a small clunk coming from both sides in the front. It doesn't seem major, nor does it seem to affect performance. When I was changing diff fluid, I put the front on ramps so I could look at the suspension components...nothing looks bad, but then again I wouldn't know how to tell unless it's physically broken somehow. Could this be bad shock(s)? I should also add that the clunk on the front left is different than the right. The right is more like something is loose and clunking around, but the left is only a small clunk. Both happen only at slower speeds...or I can only hear it at slower speeds.
2. When I accelerate in either A4WD or 4HI or LO, there is a whine that only audible for a certain segment of acceleration. Once I am accelerated I don't hear it anymore. However, the speeds are different at which it happens with 4HI and LO obviously. Also, when I have to make a hard stop in A4WD, it makes the same noise, except several times in rapid succession right before I stop and a small lurch/clunk follows.
3. When I have a make a hard stop, there is a clunk in the rear of my vehicle, usually just as the car teeters back from the stop. This same thing happens when I let go of the brake to accelerate. This only happens when I have a slow down just a tad harder than usual, and it's really hard to reproduce because it's random. Sometimes it does this, others it doesn't do it at all.
I'm just going to say that cars are not my specialty...I know how to maintain a car...but when it comes to things out of the ordinary, computer systems are my specialty
Thanks for any help!
Wesman
Wesman
