some noise help, please
Nizar
65
hii i have 2 questions
1- what is the best coil pack for tb 2006 ??
2- what can cause that strange sound like old swing when iam driving on bad road or off road ?
thank u all
Nizar
65
Me007gold said:
OEM coil packs, and Possibly bad shocks out back?
hmm is there any way to test the shocks i dont think the old way works with tb !!
Hatchet
2,405
jumping on bumper usually works.. unless u got stiffer springs in the back...
Links clunk. Bushings often creak. Shocks can do both. Control arm mounts can creak. A loose winch cable on your SPARE TIRE can make all sorts of bad noises when bumped.
You need perhaps three people. Two to jump on the bumper and one underneath to listen. Or just spray every possible bushing (one at a time) with silicone and see if the noise changes its behavior.
Nizar
65
hmm :confused: i was looking on youtube and found 2 videos, its almos the same sound
[video=youtube;rBhb6UrWomc]http://www.youtube.com/watch?v=rBhb6UrWomc[/video]
[video=youtube;qRDnGJZmYzk]http://www.youtube.com/watch?v=qRDnGJZmYzk[/video]
Nizar
65
So how can we help? :confused: You need to get under there, get dirty, and push on things until you duplicate the noise. I see nothing confusing, unless you already did that.
well first thing am going to do is to get under the car and make anybody shake it hope this will work !
fadyasha
1,134
Mine were the upper control arms. I took some Wd040 and started spraying away each part one by one and then taking a spin around the neighborhood til I finally narrowed it down. If you end up spraying everything and still got some sounds then it's probably your shocks :rotfl:
Shigueru
