soft brake pedal
Katurnbow
Florida
Long story short i had a wheel bearing go bad and when that happened my brake pedal got soft and goes to the the floor. Replaced wheel bearing, rotors and pads while i was at it and still have the soft pedal. the truck still brakes decent, the pedal is just soft and can easily go to the floor. Any thoughts?
2005 crew cab 4x4 5.3 1500
  • Wow
Reactions: movietvet
Absolutely did not crack open the brake fluid system? Correct? You did not crack open the bleeder? The hose?
If not, then you may have a damaged caliper or the caliper glide hardware is flumaxed.
benjamin.major13
