jimmyjam
- Joined
- Nov 18, 2011
- Posts
- 1,634
I am considering use my existing built 4L70 for my impala and getting a 4L80 for the SS. This would be a good time to convert to RWD as the 4L80 would need a custom output shaft to bolt onto the xfer case, vs a conversion slip yoke for RWD
RWD pros: lighter, faster, less shit in the way when i have to fix stuff, no worrying about the state of my front axle splines
AWD pros: smoke anyone when its wet out
being in florida, awd seems useless, just costing me gas and time at the track... what do you guys think?
but when i say lighter is a pro its to make it faster not more fuel efficient
i've been running a built 4l70 for a year now and its been solid...
But there is a way that you could still have 4 low and 2 low. All you have to do is disable the front actuator for the spline disconnect when you switch it to 4 low, and you basically have 2 low. I have been trying to do this, but with limited success. It would just be really giving your front diff a work out, so like you said practicality is golden.
