Chickenhawk said:
You want to be looking at the volts (V) number. It is not important what the number reads; you are looking at how fast it changes. For example, does it change rapidly several times a second, or does it change slowly, several times a minute?
Same with the STFT %. The actual numbers don't mean much; it is how fast they change.
The long term fuel trim (LTFT) % is the number you want to report because it should be relatively steady.
The O2 sensor 2 reading doesn't mean much either. It should just be a relatively steady reading.
Should it go from closed loop to open loop after it's warmed up? The previous drive it didn't go open loop.
The LTFT was all over -1.55, 2.33, 3.11, 8.58, 9.36, 11.7, 12.48.
I'm going for a drive soon and see what it's doing now.
2 previous maintenance issues with cooling system, coolant reservoir filled with chocolate brown goop that the dealer said was transmission fluid leaking into the coolant. They changed the rad and flushed the system. Oddly enough they never indicated that they had to add transmission fluid. I thought that odd since they said it leaked into the coolant, why wouldn't it need more tranny fluid?
second occurrence the coolant reservoir was filled with chocolate brown goop that the dealer said was engine oil mixed with coolant. They said that
I must have added oil directly into the coolant reservoir, other than that they don't know how it got in there. They flushed the system and sent me on my way.
I ended up to change the rad hoses as well because they were getting all spongy. I wonder if the contamination in there has caused damage to the thermostat or made it sticky.
The other thing I'll mention is the last oil change at the dealer was overfilled by about 1/4 on the dipstick. It has leaked a brown fluid, maybe oil, since then. They inspected it a week later and said nothing is leaking. But it still leaks something. Oil about 1/2 way on crosshatches now. Needless to say it's booked at a different dealer for this Thursday to change the fuel level sensor and inspect for the leak.
