Agreed, but they're not that expensive, $8 from Amazon.Just my 2 cents worth: The iridium plugs last 100,000 miles with zero problems. They are a bit costly, but with their longevity they are worth every penny (provided they aren't bogus knockoff plugs). When I was younger plugs didn't have a chance to last that many miles, so not "worrying" about them for 100k miles is nice. So I thinks: if it ain't broke, don't fix it. And the iridium plugs aren't broke (but subject to making us broke at the cost of them )
Hmm those may be worth a try, $8 on RockAutoThe acdelco plugs are made by NGK. The design is more than two decades old. Maybe these new ones from the company are improved - I can't imagine them being any worse than the OEM plugs.
The NGK part# is LTR5AHX. I would suggest that if you need plugs, you should try them
And give us a report of the results!
If I didn't change my plugs 2500 miles ago, I would do it.
FitsTrailblazer Base Model; Gap 0.050"
orTrailblazer EXT; Gap 0.044"
Is that correct?
Heed @Mooseman 's warning...In any case when using Iridium or Ruthenium plugs, the gap should not be adjusted as indicated.
To gap them, you'd have to put a feeler gauge in there to measure and that is where the risk of breaking them lies. And with those Ruthenuims with skinny electrodes on both, you might get them out of alignment. As @TequilaWarrior said, if the gap or electrodes look off, return it.Gapping can be done on any plugs without touching the electrode with the proper tool. Having said that, it should not be required if the plug was spec'd properly (ie. not "fake3") for the target vehicle.
