Got a strange issue on my 02 TB.
When in Drive at a light, most of the time the engine will shake. Some days it doesn't. This morning it didn't. I had the motor mounts replaced a few years ago. I don't think that's the problem. I've also lost MPG and the engine is running rich - so rich that when I start the car in the morning, all you can smell is gas from the exhaust pipe. Now, I got an SES of Catalyst Performing Below Threshold.
I think that running rich has screwed up the catalytic converter. The problem is, what's causing it? About a year or so ago, I had the exhaust manifold replaced. I believe it was starting to run rich before I replaced that, so I don't think an exhaust leak would be causing it.
As I got the SES on the way to work this morning, I took it to the shop. They haven't had a chance to take a good look at it yet, but said that I could need a new catalytic converter. That's probably true at this point, but what could be causing the problem that messed that up is what I'm trying to figure out.
Thanks!
Thanks!
