Rotting away
Stuntmanmike1977
84
Sanford, Maine
Hey guys. Just noticed this today and wondered how concerned should I be and is this fixable? A little worried cause I believe this holds my brake line in place!
Isn't that the same spot where the control arm is held to the frame? Or is that the Panhard bar? I had something similar on the Avalanche where a lower control arm mount broke off. The frame itself was OK, just had to fabricate and weld on a new mount.
You would have to get under there and do a thorough inspection and use a hammer or welding pick hammer to check the frame. The holding of the brake line or cable is the least of your worries. Check both sides.
moscoreli
