Rotor touches caliper on top inside of my wife's car
Playsinsnow
9,727
Alright all you VS adversaries, the forum for my wife's mazda3 is VS owned so I'm asking here :biggrin:
The inside of the pass side rotor is touching :eek: the caliper. Pad is 3/8-1/4 inch thick in view slot in center of rotor. I can post a pic later if necessary.
So why in bloody smells is the rotor and caliper making contact? I can tap it a little to eliminate the contact but it is by no means centered over rotor like the driver side is. Ideas??? :confused: TIA!
hockeyman
726
Did you check to see if the caliper bolts are loose ...or missing?
If it were me, I'd remove the wheel and begin the process of elimination by checking the two caliper bolts, guide pins, bracket bolts, etc.
Playsinsnow
9,727
yeah, I did that immediately and now I am stumped. I will try to have a more experienced buddy do the same later.
Next step? Alignment was checked and found within specs. Could they have goofed. Everything "looks" and "feels" good...:crazy:
Playsinsnow
9,727
hockeyman
726
Ohh, it's scraping on the inside.... I thought it was scraping on the outside of the rotor where the vent slots are located.
Is it rubbing at all times as the rotor is turning, or is it only at a specific spot of the rotor?
* If it's at a specific spot, I'd guess a warped rotor or bent axle.
* If it's scraping the whole time as the wheel is spinning, then I'd guess that "something like" an impact with a curb broke/dented parts within the rear pumpkin, suspension, or axle. Or all the above.
I'm no expert though. I hope someone else comes in here to clarify things a bit better than what I have mentioned. I'm just taking a shot-in-the-dark here.
"Paging Roadie...please pick up line one!" :thumbsup:
Playsinsnow
9,727
Sorry, it's pass side up front. Strong possibility it was impact? Shock and bearing went out in last 2yrs on that side.
lol, my thoughts. Couple others too. She wants to keep it!
The rotor definitely rubs the entire rotation, doesn't "sit" as it should :mad:
triz
746
I had similar situation when I was putting my car back together where the rotor was rubbing. I can't exactly remember what it was right now but something was off when I put it on (bolt,etc). I didn't have to change anything just realized a small mistake. Was something done on it recently?
Looks like the caliper bracket and not the caliper...is that correct? If the bracket is still mounted to the knuckle, it could be the hub and bearing has failed and has been pushed back into the knuckle. Not likely but all I can think of right now.
MAY03LT
Delmarva
If you spin on a couple of lugs with the wheel off does the rotor bottom out on the hub?
Playsinsnow
9,727
Bottom out on the hub? Rotot definitely slides down? Think the guy who smashed his thumb pressing old hub out (I won't say how many hours me and three others tried in a garage) goofed the install? Possible... No grinding or similar wheel bearing noise at all.
evenson1
