Hi all
I had that dreaded rumbling “wind noise” sound which started at 25mph… it got quiet turning/banking left and stayed loud when turning/banking right at speed so I narrowed down to the driver side…. Jacked up the car and front hub was tight but rear wheel could slightly rock at 12-6 position with an audible clicking sound….
So it looks like I’ll be replacing my rear wheel bearing and seal.
I read the how to post and watched some videos so I’m fine with the process but looking for advice on a couple points…
1. Is there a benefit to replace both rear bearings at the same time? I know I can just replace the 1 ok and the only real savings would be the differential fluid and small time savings related to that step so I’m inclined to leave the other alone for now.
2. Is there a preferred brand of differential fluid that has worked well in our vehicles or “anything” meeting the gear lube spec in the manual is ok
3. Would you go with a replacement differential cover gasket or use an RTV type gasket maker?
Thanks in advance
Thanks in advance
