Getting around to replacing the filler neck pipe from the cap to the tank... There are two bolts that hold the cap end of the neck to the edge of the body right inside the fuel door hidden behind the rubber gasket thing that surrounds the cap... The entire piece has snapped off, leaving nothing to put the new bolts into... See pic below... (not mine, for visuals only) ... Where the yellow dot is has completely snapped off right to the very edge. Disintegrated from rust...
What the hell do I do? It was intact when I discovered the pipe was leaking, but in the time since it's just rusted off completely...Probably the weight of the nozzle when adding petrol was too much for it...
There are zero of these trucks anywhere near me so I can't just go cut the piece off or anything like that. I suppose if I had it I could JB Weld it or something, but I got no chance of finding it...
