Recommended Rear Diff Gasket
Jkb242
270
CLT
Going to drain rear diff and refill with new oil as it may have never been changed. No issues at present simply maintenance. 179k miles.
Which cover gasket should be used paper or metal based rubber gasket?
Much thanks!
Jkb242
270
CLT
Thanks, that seems obvious but wanted to be sure this was best even with an added silicone bead. What are the realistic options should the plug be rust locked? Any recommended techniques for removal.
Thanks!
Shops would weld a bolt in the plug. The heat also helps loosen it. There are specialized sockets with a true square that will fit better than a ratchet extension with its rounded corners.
Reactions: TJBaker57
apdesigns420
