Rad Leaking
de3jr88
45
Airdrie, Alberta, Canada
Ok so I dont think this belongs in this category but i think my Radiator is leaking from the bottom corner on the drivers side. I started smelling coolant a few days ago but couldnt see it leaking anywhere. Hoses are dry, water pump is good etc. I was underneath it today and the only wet spot is in the bottom corner where the sides are connected to the core. I cant see any other spots where it is wet, and it is definitely coolant. How do I confirm this is the spot where the leak is coming from? Can this be repaired or is it better to get the radiator replaced.
RayVoy
939
Sounds like it is the rad that is leaking, and, probably from somewhere around that corner
Really hard to make a call, a lot of holes can be fixed.
You may have to pull it out, to inspect the leak, before you can tell if it is repairable.
Mark20
1,630
I had a TranSport that started blowing lots of coolant. The end cap cracked right at a bracket boss molded into it. These parts are plastic and though they last a long time don't give you many repair options other than replacement. That's the route I went on the van.
Sent from my Xoom using Tapatalk
sc repair
