- Joined
- Dec 4, 2011
- Posts
- 12,927
A few months ago my power steering quit after a single tight U turn. Figured I busted the pump. But then it started working normally again. Fluid was a little low so I thought maybe it got an airlock or something. It has been working normally until yesterday when my dad was borrowing the truck to tow a trailer. While he was maneuvering it around he made a tight turn and - you guessed it - the power steering quit a moment later. He shut it off for a few minutes while he went inside for something, came back out, started it up, and the power steering started working again after an initial heave on the wheel.
Obviously something is wrong, I just don't know exactly what. Is it the pump? Rack? Aliens?
Issues that I am aware of with my power steering (aside from it quitting twice):
1) Pump whines a little bit. It has ever since I got it 57K ago, and it isn't loud, but it is noticeable.
2) The lines are rusting.
3) The cooler evidently rusted through and the previous owner simply bypassed it by cutting the hoses off it and joining them together with double-ended barb fitting and hose clamps.
I was figuring on replacing the lines this spring and probably the pump. I technically should get a new power steering cooler also, but I'm not sure which one I should get (OEM is steel which seems junky to me) or how I should go about attaching the new hoses to an aftermarket cooler. I don't even know how the OEM hoses attach to the OEM cooler since all that was lopped off of mine by the previous owner.
Then I wondered if the rack itself may be to blame. Heck I don't know. That's why I'm asking the pros here for insight and opinions
Plus I'm not sure what part numbers I need. I know there is a high pressure pump to rack line but I'm seeing two styles on Rock Auto's site
The plan is to get another Trailblazer to replace this one whenever that time comes, but in the meantime keep this one running as reliably as possible as cheap as possible.
All have been older cars with higher miles so I didn't know any better. I just thought that was the way it was. Oil is gold, ATF is red, gear oil is brown, brake fluid is clear, power steering fluid is evidently NOT supposed to be brown. Oops... This is the first vehicle I've ever had any power steering issues with anyway
