Power Port Cap
zippy216
Can I replace one of the power port caps on the front column of my 2007 Envoy denali? The cap on the right snapped off. Also the 2 lights behind the front and rear defrost buttons are out. Can they be replaced?
Thanks
The power port "retainer" as parts4chevys.com seems to call it, is under $5 list price at the dealer. Recommend you just go there so you can confirm it's the right part when you order it. As a trim piece, it's not going to be seen in the aftermarket. Although there are MANY receptacle covers available in the parts stores. Assuming you even need it covered. Why not just whittle off the stubs of the hinge plastic and put the cap back in the hole?
Many folks have put LEDs in the HVAC circuit board, or you can solder in a replacement Radio Shack lamp. Have you disassembled modules like this and can you solder?
FWIW my cap hinge broke off on my Trailblazer and it won't stay in the socket without the hinge. I just left it off because the socket right next to it never had a cap anyway, and I know better than to stick my fingers in the outlets :biggrin:
heffarocio2380
