essaycho348
- Joined
- Mar 7, 2012
- Posts
- 58
newbie here, please go easy on me, ive done quite a few hours of searching on trailvoy and in realizing all the veterans have been banned ill just move over here, so i have come to the conclusion of needing to ask a few questions.
so purchased and installed the MarkMc 3" two months ago, cv axles and UCA flip about a month ago, then took it to get aligned. the alignment shop is very good, and a good friend of mine who owns a repair shop told me to take it to them.
After doing the UCA flip he said i have too much positive camber, and my lower control arms are pulled out all the way, he also said the passenger side is worse than the latter. the truck is also very darty in snow or wet road while hitting potholes, or while pulling a trailer. after doing much research on here trailvoy and offroadtb it seems that many people are having a positive camber problem with lift and lowered TB's and there doesn't seem to be a clear good solution on this problem.
http://i76.photobucket.com/albums/j38/dust75L/IMG_0821.jpg
So im wondering what would be better...
1. to custom fab up a lower control arm mount that sticks out farther so that its still adjustable but it fixes the camber problem.
2. to custom fab upper control arms to be shorter and fix the ball joint problem. what if the upper control arms were adjustable? to help with alignment issues and so they could work with both lifting and lowering a trailblazer.
3. screw it, its not that big of a safety or wear issue to need to custom fab anything up, run it til it dies...
with option number 2 could this bring the knuckle too close to the spring? thus needing to go with option 1?
the shop that i work at we custom build snow plows and anything else you can think of, we could fab either option 1 or 2 up i just want to know from the more experianced of us that have had the lift on for longer than i have.
our brains and others on the forum to think were crazy?
