Womack said:Could it be the PCM is bad?![]()
Womack said:No it ran fine the night before! It was a really cold morning my wife went out to start it and wouldn't turn over! No storm and didn't do anything under the hood! No symptoms prior to the no start
Womack said:It was checked at autozone! It's only 4 months old!
The cables are in good shape! No sign of corrosion anywhere
Womack said:11.91
Womack said:Both on! I took it to autozone and they said it was 80%
Womack said:I also checked to se if the PCM sees the crank request and grounds the bottom left terminal where the starter relay Is in the fuse block and it didn't ground it
These two observations cannot both be true.Womack said:Yes sir you can hear it click!
Womack said:Both off it was 12.07
Womack said:I put a different battery on and still no attempt to turn over!
The professionals you paid to do all that parts swapping had access to the same stuff, plus experience, and they failed to find the true root cause (assuming there was only one root cause.)oceancon said:...I have a meter and shop manual with schematics ...
oceancon said:Thanks for your kind reply. The dealer did not guarantee the diagnosis so I did not let him replace the fuse panel (new one was $800). I bought aftermarket and replaced it myself. It worked for 6 months and thought the problem solved up until a few weeks ago. And yes I need the truck in a no start condition to diagnose but when it happens I cant get anyone there. Last guy that came pulled some codes 1041 and 1026 (had a GM scanner) but could not find any history of hard SES codes. Another guy's scanner showed a "loss of communication with the PCM" in the past but we could not duplicate (truck was in a start condition unfortunately). I know when I pull the starter relay, it seems to duplicate the situation. But that relay was replaced. I am truly perplexed how the issue could "fix" itself for so long and then reappear. I'm starting to lean to the BCM but I think when electrical components start to go, they just keep on getting worse. So I dont think a component is failing but wiring. Each"fix" I believe is coincidence as the problem comes back.
thanks again for replies. I hope to offer solutions to other folks problems in the future because I'm pretty handy with cars but this has got me big time! Also own a nice 2005 Acura TL.
I'm not sure what the fuel gage reads or if the fuel pump is on when its in the no start condition (right now its starting) but I will check that when it happens. I also don't know about the nos. 10 and 28 fuse situation as I did change the entire under hood fuse panel (coincidentally that was one of the 'fixes' that worked for a short time). Had a weird experience last week on a long drive north and the "service 4WD light came on'. The truck would not go into 4wd or AWD. After getting home and trying to start it the next day (it did not start and then started -grrr), the light went off and it goes into 4WD again! I don't know if this relates to the BCM. Like I said to roadie is that I feel that when electrical components start to go, they eventually go, not get better. My thinking is the problem I (we?) seem to have correlates to a bad connection/bad ground somewhere. CaptainXL said:When you take the PCM connectors off there are silicone gaskets that can fall in between the pins and socket. Worth checking out.
Womack said:12.6 volts
shawnd450r said:did you ever figure anything out with your truck go figure im floating in same boat you were in
