So, there I was, getting ready to change one of my low beam bulbs. Prying clips, when one decides
to stick, then pop loose suddenly. When it did, all the other ones I had loosened came free except
the driver's side insert piece that goes across the headlight.
On the one hand, it didn't just break off, so I'm happy about that, but it did put cracks at the top
and bottom where it flexed, right where the cross piece leaves the main portion of the grille.
My question (and I put it out in case the information might help others) is, what type of adhesive would
you recommend to repair/reinforce the plastic?
Yes, replacing the cross piece is an option if I can find a color match, but I couldn't find much regarding
adhesives for repairing appearance related items, and thought it might be worth getting some opinions.
Thanks for your time!
Cheers-
Chris
Cheers-
Chris
I had something similar happen.
