Denali n DOO
- Joined
- May 22, 2012
- Posts
- 5,596
So this morning I got a check engine light showing P0171 and P0174, lean both banks. So here's what the scanner is telling me, engine warmed up to 195*, at idle short term fuel trims changing rapidly every second, both banks. Long term fuel trims staying steady at about 14.83%, both banks. I noticed from recorded info that the long term fuel trims go down to about 6-8% when accelerating and they increase as high as 20-21% when coasting and foot off gas. The light came on while coasting down a hill at about 50 km/h. The O2S S1 v #'s, both banks are also changing rapidly. Maybe not related but 2 nights ago I recorded a weird whiney noise on passenger side of engine (can listen to video). Any idea what made the P0171 and P0174 codes and might the noise be related?
[video=youtube;MwhHfw6_C8U]http://www.youtube.com/watch?v=MwhHfw6_C8U[/video]
Since you have that whistling noise, I would lean towards one of the causes that talks about a leak somewhere.
I find a light spray of carb or brake cleaner along the gasket surfaces will help pin point a leak. The engine will change RPM when you hit the spot. Also check near the top of the intake manifold on the right there is an unfinished vacuum port up there. I have seen the "cap" break off a few times causing these codes. And yes under 10% long term is normal. Good Luck to you
