oil change now engine light flashes
nbenjamin
76
did the oil change now i noticed the engine light flashed , quick that i just noticed it ....no code
MacMan
194
Did you re-set the oil change reminder?
Wooluf1952
2,663
Milwaukee, Wisconsin
^^ That^^
Is it the oil can and wrench light that's flashing? Reset the OLM.
If it's the Check Engine Light flashing, don't drive it until you know what the code is.
nbenjamin
76
Wooluf1952 said:
^^ That^^
Yes I did reset the OLM . It flash so fast a couple , I had to turn the ignition after I stop and it could only be the engine light. It's intermittent and is very quick. I will see if it does it again on the way home. The o ly other thing I did do yesterday was fill up gas after the oil change
And I did check for codes. None present
Gevans17
63
Make sure your gas cap is tight.
Spalding1028
60
Wooluf1952 said:
^^ That^^
Sometimes you need to drive it for it to set a code
gunrock
22
Funny I thought that same thing today...flashing so fast I couldn't see it. It ended up being the tail gate was shut enough to not trip the sensor unless there was enough vibration to turn the rear gate ajar light on.
gunrock
HouseDaddy
