Interesting
Also kinda lurches when I hit the gas, especially after sitting at idle sometimes, I can kind of feel the struggle of it wanting to go forward
Reactions: SnowBlazer
Mine did that when my throttle body was all gummy.
But I cleaned it and reset it. I did have the fan on 1 during the 10 min idle after the pcm fuses were put back in after waiting a few minutes. I was told to have the fan off, could that be why it's being strange? Do I have to do another reset?
Well I did tell you to make sure everything was off. How many miles have you put on it since the reset? Usually takes about 100 miles and several cycles for everything to tune in.
Speaking of strip clubs...this is more for the Midwest guys out there.
There is a strip club in Wisconsin by Wisconsin dells call cruisin chubbys. Has anyone frequented that place before?
That's a great suggestion for the 2015 Midwest meet :biggrin:
I finally took the time to type in my RPO codes and this is what I have/had aside from the upgrades I have done. Turns out it was a fleet vehicle lol
WINDOW TINTED DEEP, ALL EXCEPT W/S AND DRS Fixed Window
MOLDING B/S EXTERIOR Body Side Molding (< 200mm Tail)
BRAKE VAC POWER, 4 WHL DISC Brake WHEEL 16 X 7, ALUMINUM, SPECIAL Road Wheel WIRING
HARNESS TRUCK TRAILER, HD Trailer
CHASSIS PACKAGE PREMIUM SMOOTH RIDE Chassis
RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS Air Bags
HVAC SYSTEM AIR CONDITIONER FRT,
MAN TEMP CONT, AUX TEMP CONT Front Interior Control
PT DRESS SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) Powertrain
TIRE ALL P235/75R16-106S BW R/PE ST TL ALS Road Tire
ANTENNA FIXED, RADIO AM/FM Antenna
COLOR COMBINATION SOLID Applied Coatings
SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR Occupant Detection
FLEET INCENTIVE ENTERPRISE RENT-A-CAR (B/C/D/E/H/J/K/L/N/S/U/W 7L/3A/3Z-TRK CKGMLJSTUX) Vehicle
#N/A #N/A #N/A
CONTROL SALES ITEM NO. 06 Vehicle
FLEET PROGRAM DEALER ASSISTANCE, HOLDBACK NOT APPLICABLE (ALL PRODUCTS) Vehicle
PACKAGE OPTION 02 Vehicle
SEAT RR SPLIT BACK, FOLDING Second Row Seats
GVW RATING 5,550 LBS Suspension
REACTOR SYSTEM AIR INJECTION, ELECTRIC AIR (Air Injection to Exhaust/Reaction)
CONTROL SALES ITEM NO.100 Vehicle
VEHICLE COMPLETE Vehicle
DISCOUNT OPTION PACKAGE Vehicle
LOCK CONTROL, ENTRY REMOTE ENTRY Vehicle Access
DEFOGGER RR WINDOW, ELECTRIC Rear Interior HVAC Airflow
CRUISE CONTROL AUTOMATIC, ELECTRONIC Throttle Apply
BODY EQUIPMENT LIFT GATE (MANUAL) Lift Gates & Lift Windows
FLEET PROGRAM NON-REPURCHASE, LONG TERM DAILY RENTAL (ALL PRODUCTS) Vehicle
TRIM COMBINATION CLOTH, LT GRAY/DK GRAY (H) Interior
VIN IDENT POSITION, MULTI-PURPOSE VEHICLE Regulatory Certification Labels
PLANT CODE MORAINE, OH, USA Vehicle
ENGINE GAS, 6 CYL, 4.2L, MFI, L6, ALUM, DOHC, GM Engine
#N/A #N/A #N/A
BAR LUGGAGE CARRIER, CENTER CROSS Luggage Carrier
LAMP SYSTEM DAYTIME RUNNING Headlamps
INTERIOR TRIM LT GRAY/DK GRAY (05) Interior Trim
SEAT FRT BKT Front Seats
MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED, COLOR Outside Rearview Mirrors
TRANSMISSION AUTO 4 SPD, HMD, 4L60-E, ELECTRONIC Automatic Transmission
VEHICLE STATEMENT USA/CANADA Vehicle
PRIMARY COLOR EXTERIOR, OLYMPIC WHITE (02) Applied Coatings
COVERING FLOOR CARPET Carpet
TEST DVT, EVAP EMISSION REQUIREMENT Powertrain Integration
EMISSION SYSTEM FEDERAL, TIER 2 Powertrain Integration
STAMPING VEHICLE IDENTIFICATION NUMBER Vehicle
MARKET BRAND CHEVROLET Vehicle
COMPONENT FRT LH COMPUTER SEL SUSP (6HN) Front Suspension
COVERING FRT FLOOR MATS, AUX Floor Mats
CERTIFICATION EMISSION, FEDERAL Powertrain Integration
WHEEL SPARE """FULL SIZE, 16"""" STEEL""" Spare Wheel
THEFT DETERENT SYS 0 Content Theft Deterrent
AXLE (BASE EQUIP) FOR SCHEDULING GVW PLATE Axle
COMPONENT FRT RH COMPUTER SEL SUSP (7HM) Front Suspension
COVERING REAR FLOOR MATS, AUX Floor Mats
SALES PROCESSING OPTION Vehicle
STEERING POWER, NON-VARIABLE RATIO Steering
RADIO AM/FM STEREO, SEEK/SCAN. CD, AUTO TONE, DATA SYSTEM, CLOCK, ETR Radio Head
SPRING FRONT BASE EQUIPMENT Spring
COMPONENT RR LH COMPUTER SEL SUSP (8NS) Rear Suspension
VEHICLE GM PROD WEEK 41 Vehicle
AXLE REAR 3.42 RATIO Rear Driven Axle & Differential Carrier
CONTROL SALES ITEM NO. 104 Vehicle
COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 Infotainment
SPRING RR, BASE EQUIPMENT Spring
COMPONENT RR RH COMPUTER SEL SUSP (9NR) Rear Suspension
Took a minute to fix that mess :no:
Reactions: Sib
OptNounName OptDesc VPPSDescLower WINDOW TINTED DEEP, ALL EXCEPT W/S AND DRS Fixed Window MOLDING B/S EXTERIOR Body Side Molding (< 200mm Tail) BRAKE VAC POWER, 4 WHL DISC Brake WHEEL 16 X 7, ALUMINUM, SPECIAL Road Wheel WIRING HARNESS TRUCK TRAILER, HD Trailer CHASSIS PACKAGE PREMIUM SMOOTH RIDE Chassis RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS Air Bags HVAC SYSTEM AIR CONDITIONER FRT, MAN TEMP CONT, AUX TEMP CONT Front Interior Control PT DRESS SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) Powertrain TIRE ALL P235/75R16-106S BW R/PE ST TL ALS Road Tire ANTENNA FIXED, RADIO AM/FM Antenna COLOR COMBINATION SOLID Applied Coatings SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR Occupant Detection FLEET INCENTIVE ENTERPRISE RENT-A-CAR (B/C/D/E/H/J/K/L/N/S/U/W 7L/3A/3Z-TRK CKGMLJSTUX) Vehicle #N/A #N/A #N/A CONTROL SALES ITEM NO. 06 Vehicle FLEET PROGRAM DEALER ASSISTANCE, HOLDBACK NOT APPLICABLE (ALL PRODUCTS) Vehicle PACKAGE OPTION 02 Vehicle SEAT RR SPLIT BACK, FOLDING Second Row Seats GVW RATING 5,550 LBS Suspension REACTOR SYSTEM AIR INJECTION, ELECTRIC AIR (Air Injection to Exhaust/Reaction) CONTROL SALES ITEM NO.100 Vehicle VEHICLE COMPLETE Vehicle DISCOUNT OPTION PACKAGE Vehicle LOCK CONTROL, ENTRY REMOTE ENTRY Vehicle Access DEFOGGER RR WINDOW, ELECTRIC Rear Interior HVAC Airflow CRUISE CONTROL AUTOMATIC, ELECTRONIC Throttle Apply BODY EQUIPMENT LIFT GATE (MANUAL) Lift Gates & Lift Windows FLEET PROGRAM NON-REPURCHASE, LONG TERM DAILY RENTAL (ALL PRODUCTS) Vehicle TRIM COMBINATION CLOTH, LT GRAY/DK GRAY (H) Interior VIN IDENT POSITION, MULTI-PURPOSE VEHICLE Regulatory Certification Labels PLANT CODE MORAINE, OH, USA Vehicle ENGINE GAS, 6 CYL, 4.2L, MFI, L6, ALUM, DOHC, GM Engine #N/A #N/A #N/A BAR LUGGAGE CARRIER, CENTER CROSS Luggage Carrier LAMP SYSTEM DAYTIME RUNNING Headlamps INTERIOR TRIM LT GRAY/DK GRAY (05) Interior Trim SEAT FRT BKT Front Seats MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED, COLOR Outside Rearview Mirrors TRANSMISSION AUTO 4 SPD, HMD, 4L60-E, ELECTRONIC Automatic Transmission VEHICLE STATEMENT USA/CANADA Vehicle PRIMARY COLOR EXTERIOR, OLYMPIC WHITE (02) Applied Coatings COVERING FLOOR CARPET Carpet TEST DVT, EVAP EMISSION REQUIREMENT Powertrain Integration EMISSION SYSTEM FEDERAL, TIER 2 Powertrain Integration STAMPING VEHICLE IDENTIFICATION NUMBER Vehicle MARKET BRAND CHEVROLET Vehicle COMPONENT FRT LH COMPUTER SEL SUSP (6HN) Front Suspension COVERING FRT FLOOR MATS, AUX Floor Mats CERTIFICATION EMISSION, FEDERAL Powertrain Integration WHEEL SPARE """FULL SIZE, 16"""" STEEL""" Spare Wheel THEFT DETERENT SYS 0 Content Theft Deterrent AXLE (BASE EQUIP) FOR SCHEDULING GVW PLATE Axle COMPONENT FRT RH COMPUTER SEL SUSP (7HM) Front Suspension COVERING REAR FLOOR MATS, AUX Floor Mats SALES PROCESSING OPTION Vehicle STEERING POWER, NON-VARIABLE RATIO Steering RADIO AM/FM STEREO, SEEK/SCAN. CD, AUTO TONE, DATA SYSTEM, CLOCK, ETR Radio Head SPRING FRONT BASE EQUIPMENT Spring COMPONENT RR LH COMPUTER SEL SUSP (8NS) Rear Suspension VEHICLE GM PROD WEEK 41 Vehicle AXLE REAR 3.42 RATIO Rear Driven Axle & Differential Carrier CONTROL SALES ITEM NO. 104 Vehicle COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 Infotainment SPRING RR, BASE EQUIPMENT Spring COMPONENT RR RH COMPUTER SEL SUSP (9NR) Rear Suspension TRIM COMBINATION CLOTH, LT GRAY/DK GRAY (H) Interior
I can see you did that on a computer lol, get on via tapa and see how scattered it is
SnowBlazer said:
What? Who's side are you on? Fords aren't sexy.
First time I cleaned and reset mine we got right on the road and drove 400 miles without an issue
Lucky you, mine is a pita nowadays
Aarkon said:
Accurate^
It was a mistake
Not even close to 100 yet
rjwalsh21
