1978chevy4x4
- Joined
- Dec 30, 2012
- Posts
- 14
Hey guys. New here to GMT. Just got a 2002 Bravada a few days ago. I had no awd, did lots of research and found I needed to change tcase fluid before I did much at all so I did. The old fluid came out blue, looked clean and free of foreign material and looked to be proper amount. Replaced with auto trac II. Prior to this I wanted to see if I needed a sensor or what mught be going on. I jacked up both ends on stands and started her up and put it in gear. The case engaged the front axle as it should (to my surprise) but when reistance was applied to the front wheels with a 2x4 they would stop. I am assuming I need to rebuild it because the cluch pack is gone. I would just like some input on if my assumption is correct and if so where can I find rebuild kit because I havent had much luck.
Thanks guys
Thanks guys
